- Joined
- 23 Apr 2008
- Messages
- 41
- Reaction score
- 0
- Country
Hi Folks. I have a bit of a wierd one on my Combi that I can't work out what is happening. When I run the hot water tap at anything less than say 1/4 or 1/3 pressure, the water comes out fine, but then slowly diminishes into a trickle and hence the boiler stops firing. Opening the tap a bit more then increases the flow again, but then the same thing happens.
Like I say, if the tap is more than about 1/4 on, then the flow stays constant and hot for eternity (or at least as long as I can bear to allow the cost of the burning gas!).
I am sure that I know the answer is bound to lie in the Diverter Valve, but I cannot understand how this would effect the flow. Does the mains feed not just flow through the heat exchnager and the DV uninterupted, or is there something in it which could be effectively 'turning off the tap' for me?
BTW the boiler is a Vaillant 242 if that helps......
Cheers
Cheers
