This is a very unusual boiler fault.
Following an overnight power outage I awoke to find the above boiler spewing out thick black smoke from the flue.
After powering down and checking I found around 2 liters of unburnt oil in the base of the burning chamber that the Riello burner fires into.
I've had the oil pump assembly and injector nozzle changed as well as drying out the burning chamber and cleaning the baffles. The boiler is now running fine again.
My main concern is that this is a potential failure mode where oil was continuously pumped into the boiler without being ignited!
Anyone seen this before?
Cheers, Pete
Cheers, Pete
