- Joined
- 10 Feb 2021
- Messages
- 6
- Reaction score
- 1
- Country
I had a GRANT oil combi boiler 26 fitted three years ago as a replacement for a 10 year old, failing equivalent.
Up until recently [approx. 2 weeks ago now] it has performed faultlessly. Now, since the guarantee has expired, the boiler has decided to 'kick off.'
I checked the obvious first then called my installer/service engineer, who advised me to keep a check on the issue until my service is due, as he couldn't pinpoint the actual reason for the following fault:-
The PRV is constantly running or dripping water from the overflow pipe and the temp. is showing 2.3 bar. when the CH. is running. The expansion vessel is showing the normal 1 bar static pre charge. I have also noticed an intermittent loss in HW temp. when running a bath, although the CH. temp. seems pretty constant.
My engineer suggests there maybe a cross leakage between the HW and CH supply within the system. Either the plate heat exchanger or from another source within the house, such as a power shower connected to the supply.
I have already purchased an exp. vessel and intend to buy a heat exchanger in order to save on material costs or keep as spares if not required.
Sorry, this is a bit long winded but wanted to give as much info. as possible up front.
Any ideas please? >
Any ideas please? >
