Grant Vortex Condensing Boiler Combi 26 giving dirty hot water
Discussion in 'Plumbing and Central Heating' started by ACSB6069, 22 Aug 2019.
  1. ACSB6069
    ACSB6069
    22 Aug 2019
    Thanks Received:
    Country:
    Hi. I have a new house (18 months old) and have the above fitted outside which has been running fine and was serviced 3 months ago. It has just started to now give us dirty hot water (basically looks like someone has peed in the bath water!! The actual cold water supply to the boiler is fine and not contaminated because if I run a bath of just cold water, it is clear!
    Any suggestions, struggling to find a heating engineer to look at it, the service man that I used doesn't do repairs/breakdowns...…. please help, I'm desperate for a bath in clean water!!!!o_O:confused:
  2. Sponsored Links
  3. oilhead
    oilhead
    29 Nov 2009
    2,183
    Thanks Received:
    524
    Shropshire
    Country:
    Is the boiler pressure constant? If you are sure that the incoming water is clear, then the only contamination can come from the boiler primary water, but if there is transfer in the DHW heat exchanger, then I would expect it show as a discharge from the pressure valve rather than theother way with primary water contaminating the flow. Whilst the mains water is clean, running from the cold tap is not a valid test for the boiler supply. You need to check the flow into the boiler. It is possible for the pipework to be getting contamination before the boiler. Ask neighbours for recommendations, or check the OFTEC website.
  4. oilboffin
    oilboffin
    26 Apr 2011
    1,665
    Thanks Received:
    247
    isle of Lewis
    Country:
    All boiler men should do repairs if he only does servicing that's no good to anyone and a waste of space.If the mains pressure is on the low side eg 1.5bar when the boiler is hot the pressure could be up to 2bar and could leak through a cracked plate but you'd expect it to blow off the prv bit of a puzzle.Bob
  5. oilboffin
    oilboffin
    26 Apr 2011
    1,665
    Thanks Received:
    247
    isle of Lewis
    Country:
    Question can someone tell me why when I'm on any subject we get the spectacles on it why are you looking at me mod
    • Like Like x 1
  6. ianmcd
    ianmcd
    15 Aug 2010
    24,084
    Thanks Received:
    10,158
    Livingston
    Country:
    How do you know that they are looking at you ? does it show up ?
  7. muggles
    muggles
    28 Oct 2005
    13,438
    Thanks Received:
    3,108
    Daventry
    Country:
    It means you're watching the thread and getting notifications for replies. The KGB aren't watching you
    • Like Like x 1
  8. dilalio
    dilalio
    20 Mar 2009
    8,196
    Thanks Received:
    1,375
    Potters Bar
    Country:
    I think that would show as a Bowler Hat! :LOL:
    • Like Like x 2
  9. oilboffin
    oilboffin
    26 Apr 2011
    1,665
    Thanks Received:
    247
    isle of Lewis
    Country:
    Much relived.Bob
  10. Sponsored Links
  11. oilhead
    oilhead
    29 Nov 2009
    2,183
    Thanks Received:
    524
    Shropshire
    Country:
    Just because you're paranoid does not mean they are not out to get you!!!!!!
  12. Madrab
    Madrab
    4 Oct 2012
    8,570
    Thanks Received:
    2,483
    East Renfrewshire
    Country:
    @ACSB6069 ... post your rough location .... someone on here may be able to visit or recommend an engineer who can look at it for you.
  13. Terrywookfit
    Terrywookfit
    19 Jul 2007
    5,786
    Thanks Received:
    1,096
    Country:
    As you say Bob.....But as we both frequent that other Forum, We know it is not the case !!
    I would definitely lose customers.
    A bit like taking your car to the garage to be told,,,,,,It's your water pump we only do oily bits !!!
  14. oilboffin
    oilboffin
    26 Apr 2011
    1,665
    Thanks Received:
    247
    isle of Lewis
    Country:
    Dead right Terry these one jobbers get me wound up.Bob
  15. dilalio
    dilalio
    20 Mar 2009
    8,196
    Thanks Received:
    1,375
    Potters Bar
    Country:
    Blame Karl marx and Henry Ford... Division of labour... No "employee" is allowed to "own" their work anymore :cautious:
  16. oilhead
    oilhead
    29 Nov 2009
    2,183
    Thanks Received:
    524
    Shropshire
    Country:
    So another problem goes away. OIt would be polite for the OP to keep us updated after we spend time helping.
  17. dilalio
    dilalio
    20 Mar 2009
    8,196
    Thanks Received:
    1,375
    Potters Bar
    Country:
    Snowflakes eh! :rolleyes:
  18. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
