Grant Vortex Pro 15/21 leaking in case.
27 Feb 2020
Hello
I have an intermittent leak in my Grant Vortex Pro 15/21 inside the case. Never very much water but the bottom of the case has sometimes 3mm of water. I have checked the flow and return connections but can't find any leak. The boiler is about five years old. Has anyone any ideas what may be causing this leak.
diode84
I think I have found it, the drain tap at the bottom of the boiler had a drip on it. I tightened it.
I did tighten it but there is still a very small leak and didn't dare tighten it any more as it looks a cheap brass drain tap. Any idea if its the one with 'o' rings or the cheap one?
Buy a new drain off take the guts out and fit the new bits into the old body. Bob
As Bob says. There wont be an O ring, but a rubber disc. When you do replace just the 'guts', make sure you clean the seat first.
Yes good idea but will have to wait till I drain the system to add more rads.
If the boiler was installed with isolating valves on the flow and return, then cl sing those off and screwing down the auto air vents, prepare the new tap with ptfe on the threads, open the drain valve to relieve the pressure in the boiler.If you are quick, you can change the leaking item without draining down and only losing a few drops of water. Don't forget to open up the AAV's upon repressurising.
