Hi there,
Planning on creating a vented gravity loop going into a hot water cylinder.
The F&E tank is one of these:
http://www.polytank.co.uk/polyred.htm
It allows for a 22mm Feed and 22mm Expansion pipe to be fitted to the loop.
The hot water cylinder has a 28mm coil specifically for solid fuel appliances.
Now everywhere I read I come across 28mm minimum for horizontal runs and 22mm for vertical runs, which both the F&E and Cylinder seem to comply with.
The issue is this....
The fireplace we have only has 1/2" - 15mm outlets on them!
(Sorry for the foreign website, but its the only one I can find easily with the technical drawing of it. http://www.obchod-kominex.cz/krbova-vlozka-teplovodni-hakr-trade-zeus-301-v-16kw-3326_detail/ )
So in short all that is available are 2 15mm outlets at the top and 2 15mm inlets at the bottom, presumably created so you can cap one end off and plumb it in whatever way you wish.
The sectional area of a 28mm pipe is approx 540 mm² where as 15mm is approximately 135 mm²
Even if you were to use both top outlets for the output and both bottom inlets for the input you'd still only be at 270mm² before connecting back onto the 28mm.
Is this likely to cause a huge bottleneck in the system?
How would you plumb this, take the 28mm right up to the back boiler and reduce it down to 1/2" and screw it directly in, but only using one input and one output?
Or reduce down to 15mm and split it both ways to use all four connections?
