Class II wireless thermostat receiver.........I wonder whether that item actually qualifies as 'a point or accessory' of the installation to which it is required to run a CPC.
Yes of course it does and a CPC is required.
Let's face it, it's theoretically possible that the item might come with a pre-fitted cable which had no core for a CPC. As I said, it's really analogous to any situation in which some Class II item is 'hard-wired' to an FCU - do you believe that the regs require a CPU to be run 'beyond' that FCU and, if so, how would you set about complying with the regulation if the item in question came with a pre-fitted 2-core cable?
If the item is pre wired and the flex can not be replaced then as long as the point it is connected to has an earth connection then this is compliant.
