Greenstar 25/30is top up pressure with key ?
16 Oct 2004
Hi all,
We have a worcester greenstar 25/30is and I need to top up the pressure with the key but have forgotton how. The supplied manual is next to useless.
I remember the plumber showing me where to insert the plastic key, turn this and turn that, watch pressure gauge, set and done.
Anyone care to remind me ?
Many thanks for that :D
Its back up to about 1.2 bar where the plumber had originally set the dial.
However I am a bit worried that it had slipped down to 0 bar (absolute zero) and took a lot of water to re-pressurise. Could this be a mains leak or maybe ch system leak ?
Thanks again
The leak will be from the CH system, check all pipework and radiators.
However if this has not been topped up since it was installed and that was over a few months ago then it might just have been some air released from the AAV or have you blead a rad??
Thanks for the replies.
This is the first time ive topped up since it was installed last year. It dropped a bit a few days after installation and ive only noticed it was at zero today.
There are no visible leaks and I think I may have bled a few rads a few months ago.
I wont worry about it unless it drops really low again.
Thanks again, great forum :D
