I am wiring via a 10 terminal box to the greenstar 30 cdi boiler that has a built in programer and room stat (radio) , and have a cylinder stat, 3 port valve and zone valve.
Because there is no room stat or programer to connect and I only have live switch and live return from the boiler (excluding boiler permanent supply) I need to alter the y plan set up in the junction box.
I know that linking 4 & 5 will remove the need for the room stat and presume the boiler will switch the integral pump on or off as needed.
If anyone has come accross this before and remembers what terminals they swaped in the 10 way box any help would be appreciated.
Thanks, Mark.
Thanks, Mark.
