Hi Guys,
My boiler isn't firing up when CH demanding heat by the room thermostat.
Symptoms are:
When demanding heat - green flame light illuminates and fan runs up.
After about 20 secs the fan slowly runs down to a stop and the green flame light goes out.
The boiler is now all quiet as the temp gauge quickly rises to 90 then slowly cools to around 50 after few minutes .
I am assuming the gauge is monitoring water temp in the boiler as the pump isn't running.
I switch off/on the mains to the boiler and it carries out its normal 15min re-cycle, after which the boiler heats up my radiators as it should.
But when the demand for heat is off overnight, the CH does not kick in again in the morning, and have to repeat the on/off sequence.
Very frustrating as there are no error codes showing any time.
All radiators have been vented and system pressure is at the normal 1bar.
The boiler is serviced annually.
Any thoughts?
Cheers All
Symptoms are:
Any thoughts?
Cheers All
