grey water
1 Apr 2006
bled a radiator the other day and noticed the water was a bit grey/blackish colour what does this indicate if anything thanks
Iron oxide, =rusty radiators. Can cause sludge - do a search on that.
thanks for reply chris house is only 5 years old so heating system same age can sludge occur in newish system
steel + water + air...
Try it with a wet nail, it will start to rust in minutes.
It will happen with a new one if not filled using a chemical corrosion inhibitor.
fernox used to supply a nail+small jar with their inhibitor .......installed `74...nail still bright in the solution :o
