Another problem with this heap of junk! I put the car into 1st and while letting the clutch out to engage a grinding noise came from the engine area followed by the car juddering slightly but once I let the clutch up and got moving the car drove like normal and then as I went up or down the gearbox it would grind and judder as the clutch engaged and then drive like normal, and I didn`t have any trouble getting it into gear. For the last 3 to 4 months sometimes i`ve had a funny squeaky noise from the clutch area like something was spinning and rubbing somewhere and it just didn`t sound right so I don`t know if its related. Its a Citroen Saxo X 1.1i, 98 S reg. Is this a minor cheap easy to fix problem or expensive?
