Hi, could someone please advice on the correct installation of this concealed unit? I've searched a lot on a web, but could not find any useful information.
What I am trying to understand is what type of fittings shall I use? The easiest would be a compression fitting, but I am afraid to use that, i.e. what if leaks behind the tiles?
On the other hand, the manual says no soldering connections are possible at the unit. So the only possibility then I can think of is to use an adapter, i.e. threaded -> solder. But then I guess I have to first solder a short pipe to the adapter before putting the adapter into the unit, to prevent overheating while soldering (adapters are pretty short). Or is there a better way of doing this?
Thanks!
Thanks!
