C
carlosfandango1976
Hi all, i've been reading previous posts on grouting. Just tried some b&q 2 part grout (assume it's epoxy.) Had no luck really as it was a pig to clean off the edges of the tiles after going over with the float. Basically it was that sticky i ended up pulling out that what I had already put in the gaps, also it went off really quick and I ended up raking all of it out wet as it looked like a dogs **se. Yet to try again....
In other posts people have recommended using a powder grout mix, rather than the epoxy ready made stuff. Will this require further sealing to prevent it from discoloring? i.e with an acrylic sealer?? As i assume it's more porous..
Any help would be greatly appreciated..
Rob.T
Rob.T
