good
You might need two people to help[ diagnose the defect
You have a got a summer winter control on the cylinder
Get someone to stand near the boiler and you near the cylinder
Place your hand on the primary pump (the one that runs when boiler fire- other pump will run when the timer comes on)
Reduce the summer winter setting
If the boiler was running at that moment in time, boiler will shut down, but the pump will run on a bit
If boiler and pump are off, adjust summer winter control to winter.
Pump and boiler will run
Reduce to summer settings
Boiler goes off but pump runs on for a short time
Get the flue checked as the system is old and often inner tube corroded
Replacement is still available; I have a replacement available if it is required
Also get an engineer to remove the fan and clean the main heat exchanger as this work is often ignored and heat exchanger is often well bunged up with combustion debris
I suspect it is not a pump problem
Good luck
Good luck
