Hi all advice please if possible
I need to replace the drain /gulley but I've no experience in them at all
Are they fairly bog standard as for sizes and pipes
The one I need replacing is made of concrete I think and it's cracked on the top and along the inside when I've checked inside there seems to be a u bend heading right and that must go to the sewer
Can you let me know if it's a straight swap to replace and also the drain is really only used to collect the rainwater from the roof as ground water runs away from it
Kev
Kev
