Gulley replacement
15 Mar 2006
Tyne and Wear
Hi all advice please if possible
I need to replace the drain /gulley but I've no experience in them at all
Are they fairly bog standard as for sizes and pipes
The one I need replacing is made of concrete I think and it's cracked on the top and along the inside when I've checked inside there seems to be a u bend heading right and that must go to the sewer
Can you let me know if it's a straight swap to replace and also the drain is really only used to collect the rainwater from the roof as ground water runs away from it
Kev
Easy enough to replace if you choose to. You'll need to remove sufficient block paving to be able to access the gulley and the pipe leading away from it. Looks like its made from salt glazed stoneware, commonly used in the past. Gulley and trap will be made in one piece so there's no option but to remove the lot.
Dig out and expose the gulley and enough of the outlet pipe to be able to access with an angle grinder. You may find it is only the surrounding soil holding the gulley in place, in which case, slight movement may free the gulley from the joint to the outlet pipe. If not break it away carefully.
Cut outlet pipe with angle grinder, and chamfer cut edge. Fit a suitable connector to adapt salt glazed to plastic. (This might be ok... http://www.screwfix.com/p/flexible-adaptor/19914 ). Offer in new gulley, (bottle type is my preference as they have built in access for rods or jetting hose), cut piece of 110mm plastic pipe to go from gulley to adaptor, fit gulley and pipe. Good practice to bed gulley on some concrete and haunch with concrete to hold it in place. Protect and exposed plastic pipe with peagravel
Backfill and make good paving. May need to cut some paviors, depending on size of gully top. Something of a similar size may be available, such as http://www.screwfix.com/p/back-inlet-bottle-gully/12051 but there are also hoppers available, but you'd need a seperate trap with these.
Any idea if this would replace the top half that is broken To save ripping it all out, if not I'll start the digging
It's 110mm
I will do cheers Hugh
My only concern is that it's not all covered in concrete as I will have to break up some concrete to be able to remove the gully and trap and install new pipework
Hmmm, might get away with that. Looking at that i'd either try fitting a new hopper into that, or even obtaining a circular grid to fit whats left, then installing a gulley surround and benching it to form a new gulley.
Inside Diameter of inner is approx 165mm the outer lip
Is around 190mm
Ideally if I could get a hopper to fit, any ideas if there is some sort of rubber reducer or something to make a nice fit, surely this must be a common thing
Kev
If you've managed to remove the old hopper is (virtually) one piece, then may be worthwhile going to a builders merchants and asking if they've anything suitable. Screwfix and the like only stock plastic drainage, but some of the independant merchants often have racks of clay drainage (some of which has been lying around for years!), and might just have something suitable.
The hopper I've removed is split in two, the gully is fine no cracks so just need a hopper really, wonder if I could make a cust one out of the readily available 110 plastic ones
You could, its getting a seal between the plastic spigot and the existing pot, AFAIK no adaptor is available to make a proper joint. If the plastic hopper was set in concrete it should be fine, just endeavour to make sure you dont fill the clay pot up with concrete whilst doing it! Provided the water can run away ok it should suffice, what you dont want is water leaking out into the surrounding soil and soaking the founds of the property.
I've had a poke through Hepworth and Naylors catalogues, neither appear to make a clay hopper to suit what you have there unfortunately. :( Either complete gullies or hoppers akin to the plastic type you've already seen.
Thanks for help here hugh really appreciate it
I may have found one solution, this would fit in the lip
http://cgi.ebay.co.uk/7-Round-Cast-..._Plumbing_MJ&hash=item4cf77b4ea5#ht_600wt_689
Although i might do what you said and fit a plastic one and concrete around it i think that may be the neater option
Anyways see what you think of the grill i found
Yes I think that would work just gotta make sure I can still remove grill to clean when fitting gulley surround
Kec
