Hello all - been a while since I've last posted. My DIY woes have been fewer lately!
I was wondering what people thought of this situation. The front of my house has the normal setup of gutters and eaves. I have noticed that I'm getting wet marks at 2 points after it rains. It seems to be damaging the underside of the eaves as you can see where paint is flaking when you stand under it.
I have attached a photo so you can see both points.
I have had someone out to have a quick look and their response was "you should replace your gutters". Now, if that's correct, fine, but can overflowing gutters cause this kind of issue? If water flows over a gutter can it reach and damage the underside of the eaves?
What I don't want to do is get these replaced, at cost, only to find that it's a slipped slate or something else further up the roof and the water is running down then coming out inside the eaves, thus draining out the bottom and damaging it.
I cannot see the gutter/eave combination in close enough detail to tell if water flowing over the top of the gutter would flow into the eaves.
Hopefully you can see from the left hand leak in the image just how close the wet mark starts from the eave - if the water was coming out the gutter could it mark this far up?
When it is absolutely chucking it down, the gutters do struggle to cope and can overflow a little, but this water marking is occuring in light rain, when there is no overflow.
Any suggestions would be great, and apologies if you can tell absolutely bugger all from what I've said/shown!
