H profile concrete posts - aggh!
15 Apr 2005
Yorkshire
I want to make my own featheredge-on-rails fencing. But Not keen on using wooden posts - I'd like to use concrete, but clearly most concrete posts are designed for panels, with their H profile.
Are there any concrete posts with holes for bolts? I'd need 9ft posts (fence is 6ft6). Is there anywhere locally that I might find them? I have found similar stuff online, but there isnt much variety and technical details (position of holes) is sparse! I'd feel much more confident if I could see the posts in person and measure it!
An alternative might be to adapt standard slotted concrete posts. Perhaps some framework in the slots onto which I fasted the rails? Or metal straps around the posts at the height I need fixings? Some kind of clamps? Eventually the featheredge facing will be on both sides (double sided), so appearance of any kind of "bodge" isnt very important!
I dont need gravel boards (though there will be a "sacrificial" piece of featheredge mounted horizontally across the bottom of the fence between the verticals and the ground).
If not, how best to protect wood buried in the ground in concrete? I would be using 4x4 wooden posts. Cheers.
How do they fix gates to concrete posts? Something I always wondered!!!
you are over thinking it. The slotted concrete posts have holes in the middle -presumably used during the the casting process? Just put pressure treated timber in each side of the slot and a couple of long bolts to sandwich the lot together. Then fix your arris rails to those vertical timbers. Or do you mean something different?
I screwed 4x2" wooden batons to mine, using long screws and rawplugs.
You have to be careful with your choice of rawplug and hole/screw diameter though, as there is a risk of splitting/damaging the post.
If you drill through the narrow part of the 'H', you avoid the metal reinforcements in the post.
The gate hinges/fixings can then be screwed into the batons.
