don't use the img tags, click under the reply window where it says "show my images" and then just click on the picture you want to insert...
anyway, can't see clearly from the picture but you just want another light to come on with the existing one?
you just use the neutral andswitched live ( and earth ) from the existing light to the new one..
if it stays on then you got the wrong live..![]()
On the same wall...yes straight horizontal from one to the other is allowed..
However, the switch is to the right but lower down, this wiring would not be in a safe zone.
Can you not move the switch so it is in a vertical line with the RHS light and incoming supply?
yes it would.![]()
the switch creates it's own vertical and horizontal zones which intersect the vertical and horizontal zones of the lights..
as long as you don't go diagonal the cable will still be in a safe zone if you route it as shown.
Your album is called "House Re-Wire".Is this an acceptable layout for wiring my two wall lights in the hall. I was more interested in the link between the two lights and if this would be identified as a safe zone to run the cable in?
If you're still at the stage of learning things like this then you're still quite some distance away from the stage where you can safely tackle a rewire....
yes it would.![]()
