I had 4 Halogen spotlights professionally fitted a year ago in my bathroom. Recently one bulb died so I changed it for another but it was 35W and I didn't realise and i replaced it with a 50W bulb
It worked fine for a day then wouldn't work but if I took it out and jiggled it a bit it worked again for another day and so on for a few days
After a week I checked with one of the others that the bulb was correct and then realised my mistake. The wires connecting the transformer to the GU4 terminal were staring to melt so I removed the bulb and the wires. I am trying to order a new GU4 connector but can't find any anywhere. I have a GU10 so first question , I assume I can mix and match ok?
Second issue, though is that the bulb I removed to check the wattage started doing exactly the same thing. It worked for a bit then didn't but would if it was reseated for a bit and its wires are also starting to blacken as if they are melting but this is exactly the same bulb that has always been in there. Any ideas?
