halstead ace he
18 Apr 2009
South Australia
Hi i hope someone can help figure this out, The boiler works for hot water but when a call for heat for the central heating nothing. Checked the room stat by putting link back in, I checked the clock has 240v. I checked there is 240 between blue and orange wire on x1a and x1b. The pump runs so that's ok, i took out the diverter head and that moves out under power. Has anyone come across this before as I'm thinking pcb fault.
there's no programmer except the mechanical clock on the boiler. i checked and that's got 240v, I linked out the digi stat.
Check you really do have a n external call for heat.
Also check the microswitch on the diverter valve, then the primary thermistor.
