I'm relocating my kitchen s/cock and, as I've done before, went to close the 76 yr old pavement supply cock. After a few turns it stopped turning but water was still flowing, next I unwound it to consider plan B, however the spindle had seized and the entire mains cock came off leaving an 18" high water feature on the pavement and a trickle in the kitchen so I switched the boiler off. Severn Trent arrived and plugged the leak with a long plastic rod but my trickle stopped and back flowed (could feel a vacuum on the garden tap which I'd left on to spit out any stones or debris). They removed the plug and eventually replaced the valve using a 6 foot socket spanner. Prior to this the boiler was working fine, but when I fired up after the pavement leak was fixed the boiler came up with error code 1 (water temp >105c).. suggested action (1) Check no air in HE / CH system (2) Check plate HE not blocked (3) Check diverter valve operation (4) Check Flow / Return Thermister.
