- Joined
- 22 Dec 2020
- Messages
- 2
- Reaction score
- 0
- Country
Good Afternoon.
I have what I can only describe as an overflow pipe that leads out of the bottom of the boiler (seems to be connected to other pipes and leads out of the wall and terminates at 1st floor level through the wall outside. From this pipe I have developed a constant drip of water every second of so which is causing a loss of pressure in the boiler.
To keep the boiler running I have had to unscrew the water flow valve a touch just to keep a constant small flow of water into the boiler to maintain pressure.
Obviously after the permanent fix to this and want to know if its something I can do?
Simon
Simon
