I have a Halstead Ace in my 2 bedroom house. The boiler is less than a year old and has been problem free until about the past couple of weeks.
The hot water has started to run intermittently cold. This seems to caused by the burner cutting out after only 10 or 15 seconds, then re-igniting after about a further 20 or so seconds. The boiler continues in this fashion indefinitely, regardless as to whether the CH is switched on (although the water seems hotter when the CH is on). The CH by the way, seems to be operating fine. The rads get hot as quickly as usual, and the burner stays on with no apparent problems, until the hot water is run. Then the burner commences to burn intermittently again.
I can think of only one possible forbearer to this problem, a few days before the boiler became problematic, there was an interruption to our water supply at the mains. This lasted for just over 24hrs. I'm not sure if this could have caused the problem.
Any information, questions or suggestions will be gratefully received.
