I think that the plate to plate heat exchanger has become blocked on the central heating side and this is stooping the water circulationg around the boiler and causing it to boil
had this problem several times on this boiler, pop and new one in and bobs your mums bro
Cheers Corgiman but tried that already.........had problems with dirt in the DHW HE in the past but this has caused the burner to go on and off, I guess due to lack of flow....what's the chances that the primary could require cleaning ?
system was cleaned and inhibitted with Fernox CH Restorer and CH protector in Nov. 2005. The primary has never been removed and cleaned since the boiler was new some 3 or so years ago......looks straight forward enough to take out....are there any obvious gotchas to watch out for ?
Two screws at the bottom....is that the DHW HE you are talking about ? if so it's the primary I want to remove. I have to say that these boilers usually get a bad write up but i've found this one not too bad...I live in a hard water area so it pretty much doesn't matter what you have it's open to attack.
another problem with a halstead (sucks in air does best victor meldrew impersination) I DO...... NOT BELEEEEEEEEEEIVE IT! rapidly going off idea of mine being fixed... thinks ill buy a new 1.
