Hi All
Does anyone have experience with a Halstead Quattro Boiler. I'm an Electrical Engineer to trade and know where to draw the line with other trades skills, but am looking for a little bit of advice before purchasing a £300 part
Question.
My Domestic Heating and Hot water is off due to the Burner not fireing up. 1. The pump switches on 2. The fan assembly is running. 3 The electronic ignition is operating , i can see the blue spark but no ignition takes place.
240vAC is supplied to the Gas Valve coil but i don't think there is any gas out of this block. The part is a Honeywell Gas Control valve with a modulator control. This is the area where i stop and get a Corgi Registered Engineer to replace it. Question is do you Heating engineers think this is highly likely to be a sucsses replacing this Gas Valve. It is quite expensive to diagnose the problem wrong but cheaper than a Boiler replacement. Any advice appriciated
Question.
