Hammering Noice on switching OFF hot water mixer tap
4 Oct 2013
Essex
Need suggestions !!
I have got a problem on closing off my kitchen sink mixer tap. Specifically, on closing HOT water part, there is banging noise. This appears only if I quickly close off tap....else there is no problem.
I did took off AIR but it doesn't help. After taking air out, banging noise do not appear for 3-4 days and then it starts appearing again.
Regards,
Either loose pipework,worn tap washer,worn ball valve/float valve washer.
I take it the tap in question is a 1/4 turn tap?
Thanks for responding!!!
This noise is coming only from kitchen sink tap so is it fair I localised this problem to tap washer only?
Not sure of size....hence uploaded image itself.
Regards,
Turn your stop tap on a bit more.
It could be the loose jumper getting a shock wave from pipework and slamming the washer back on the seating.
Sounds technical but very basic.
Jeff
