Handle pulled off window and frame cracked
11 Oct 2016
Hi, the handle and part of the mechanism has been pulled off and part of the frame too.
Can this be repaired?
Maybe by using a metal plate ?
Window lock mechanism will need replacing and new handle.
I've fitted s few universal mechanisms as could not get exact replacement.
Metal plate over may work if you can glue and screw it well enough to hold I guess.
Wouldn't a metal plate bring the mechanism forward though, creating pressure on the internal structure, assuming it will 'almost' line up?
Thanks, Is this something I can do as a pretty good diyer or do I need to get a window repair guy to do it?
I've never come across this problem so don't really know what's involved, sorry.
You need a new handle and lock mechanism, both fairly cheap ( just replaced two of mine at about £20 for the pair ).Unscrew the handle and remove the lock, then you could glue a strip of uvpc trim over the area to repair ( redrill hole to accommodate lock spindle and screw holes) when buying a handle get one with a cam which is slightly longer than existing to pass thru the extra depth of the repair .
You may have to trim a longer cam to size if you can’t get a close match .
DIY job.
Take handle off. Few screws from outside and off comes latch. Couple of minutes job.
Look at numbers. order another.
That's the easy bit.
Metal plate is a bit more effort.
Depends If you like DIY and interested to have ago
