    Dismiss Notice
Hanging a double oval radiator question
Discussion in 'Plumbing and Central Heating' started by vaderag, 13 Jun 2019.
  1. vaderag
    vaderag
    30 Jun 2011
    104
    Thanks Received:
    Kent
    Country:
    We purchased a double oval radiator a while back and are just getting around to fitting it - we noticed that one of the columns is actually manufactured incorrectly and at a slight wonk, which throws off the look.
    The rad does have a labelled back and front, but if I was to fit it with the back facing outwards the wonk would not be visible. Whole thing is being replumbed so we can still make the inlet and outlet match what need to be...
    Can anyone advise what the issue would be if we fitted with back facing outward?
  2. Sponsored Links
  3. terryplumb
    terryplumb
    8 May 2017
    5,837
    Thanks Received:
    1,195
    Country:
    Probably no difference ,but why not return it for replacement ?
    Can you post pics of the rad ?
  4. vaderag
    vaderag
    30 Jun 2011
    104
    Thanks Received:
    Kent
    Country:
    It's one of these
    [​IMG]
    I'll try return but been hanging around a while so not sure in date
  5. ianmcd
    ianmcd
    15 Aug 2010
    22,199
    Thanks Received:
    8,777
    Lanarkshire
    Country:
    as long as it does not have a baffle fitted it shouldnt make any difference, cant see why it would have a baffle but some do
  6. vaderag
    vaderag
    30 Jun 2011
    104
    Thanks Received:
    Kent
    Country:
    How would I know?
    The confusing thing is, if there's no reason that it would make a difference (which i agree I can't see any reason why it would), then why would they feel the need to label back/front
  7. terryplumb
    terryplumb
    8 May 2017
    5,837
    Thanks Received:
    1,195
    Country:
    Even if its fitted with a baffle ,it won't make any difference ,as long as the feed and return are tubed to the correct ports. Is the brackets positions the reason for front / back I.D ?
  8. DIYnot Local
    3 Sep 2019
    Country:
  9. Sponsored Links
Loading...
Share This Page
