Hi all
Excuse the title but unsure how else to word it.
I'm hanging a massive mirror in mum's house using plasterboard fixings (the metal spiral shaped ones). First one went in fine, but the second went in about an inch before hitting a solid surface and going no further (thus just churning a hole in the board).
I cleared the hole out a bit to try and see if it's a wooden stud, or a metal channel covering cables or something but it's not clear. I don't think it's wood from the feel of it (jabbing in there with an insulated screwdriver) but brick wouldn't make much sense either as the other one (30cm to the left) went in without issue.
I wouldn't expect it to be covering leccy wiring really. The circuit board is about 6ft to the left of it and the only leccy thing on the wall is a double socket further over to the left (but then what would I know).
Anyway, what would you suggest here? I don't want to drill in case it is wiring back there, and there's not enough cavity space to get one of the types of fixings in which open up behind the wall...
For context, it's a mid-terrace 30ish year old house in England.
Suggestions warmly welcomed as ever! Let me know if you need pics or more info please, ta.
Matt
Matt
