Hi guys. In an ideal world, the lighting circuit would be as in the drawings, feed into the pattress or fitting, cable off to the switch and loop on to the next fitting.
However, is there anything to stop you running the feed into the switch box, connecting the neutrals in a connector and then running on to the light fitting? Or, for that matter, doing it all in a 20A box stuffed into the studwork and then looping on to the next light from there?
What about a mixture of all of the above in the same circuit?
Obviously I'm assuming its all drawn up and documented and all lives are brown sleeved etc. and everything buried is RCD protected.
The reason I'm asking is that so many light fittings now have no room in them for more than 3 wires and its much easier to run a single switched t&e to a fitting than one to it and another from it.
Sorry if its a bit obvious for those of you with loads of experience.
Any 17th refs you could point me to?
Cheers
Andy
Cheers
Andy
