Hi Guys .. Hope you can help, I've checked the search option for this and don't seem to be able to find the answer I want so here goes. We have moved into a house with 2 hard wired smoke alarms, both have battery back up. If you replace the battery they beep as if the battery needs replacing if you pull the battery tray out they go silent. My point is this , is it easy simple enough to take these down and replace with normal battery models. Doing this would enable us to use the 'spare' fuse to have lights fitted near the front and back doors or am I barking up the wrong tree
Thanks in advance
Thanks in advance
