Hi folks, bolt that holds on blade will not budge! Looked through some excellent posts, nothing works, not able to try heating outer metal as run out of gas for blow tourch. Done the dam, with blue tack, round the nut to hold in WD 40 over night - all good stuff! Will try fine oil all round next.
Second prob., trying to get lever at the end of throttle cable released. Have drained oil ready for oil change so have mower leaning, away from filter, just able to sqirt WD 40 up around lever. Need to sort this or will end up having the thing running away with me.
Many thanks, sure there is someone in the know out there!
