Does the boiler fire up when there is a demand for hot water only? whilst the hot tap is open does the burner cycle on/off? and do the other radiators get hot apart from the two that don't?
pressure is at 1.6, all radiators gettin really hot just 1 up n 1 down that are not, boiler seems to fire up n then off pretty quick after when hat water tap is running
Sounds like a blocked plate heat exchanger for the hot water problem, if the boiler is continually cycling on/off when the hot water tap is running. Rads not getting hot could be trv's playing up on the rads , system needs balancing or sludge in the system causing circulation problems.
