Whichever room you most want warm in the morning should be one of the ones that can call for heat.
Why not all rooms being able to fire the boiler? In my case cost is the reason, the radiators are on outside walls, yes I know that's an old fashion idea, but that's the way it is, so each room would need both a smart TRV head and a wall thermostat linked, so a cold wall does not activate the boiler, it has to be a cold room.
But then we have a secondary problem, a boiler firing up just to heat one room.
I can accept a room at 18 - 22°C, for intermittent use, so a non linked programmable TRV head set to 16°C overnight and 22°C during the day for example the dinning room, is acceptable, for the living room want it 20 - 22°C and the dinning room radiator is far bigger in relation to room size to living room, so the TRV head does not need to be linked in the dinning room.
This can be repeated throughout the home, my bedroom only has one window, wife's has two, her room North facing mine South, so both rooms have programmable TRV heads, but only her room needs to be linked, so if not linked it can be set to 18°C at night, 16°C in the day, but do that with a linked TRV head, and it would fire the boiler because the wall is cold, not the room, so it needs a wall thermostat on an internal wall or free standing.
But the times set are important, if the dining room set 10 minutes before living room, then living room will open before the boiler has shut down, but set to 20 minutes, boiler will shut down and likely at least ½ hour delay before it cools enough to re-fire. So setting a sequence so rooms are heated in a set order can both reduce and increase re-heating times, depending on delay set.
On moving here, what became apparent, is there is no one system that suits all, what had worked in mothers house, did not work in this house, so had to work it out from scratch again.
Re-heat times do seem to be slow, radiators are hot, so only way to speed up would be fan assisted radiators, but then can't use TRVs, so there is no magic wand fix.
