im looking for a replacement light fitting 240 volts controled via a dimmer swtich, which is heat resistant . The light fitting is going inside a chimmey breast were a mutli fuel fire is fitted , the fire opening is very large and the light fitting can be fitted well away from the fire , the only direct heat which is passing the light fitting is the heat coming from the flue pipe , the light fitted previous was a kitchen strip light which does not work anymore
any help would be appericated
