'heat resistant' terminal strips?
10 Feb 2007
Norfolk
Hello and thanks to all that reply,
I've just finished replacing an oven cable from the cooker connection plate to the connection at the oven. During which I found the connection point (oven end) cracked and unsafe. I have used a terminal strip, of coreect Amp rating, to make a temopary connection but am wondering if the replacement will be acceptable? The terminal strips are the standard type and as such are 'heat resistant' but is this enough? Obviously, all the internal cables are joined here and so there insulation will be subjected to the temperature in this zone. I have seen ceramic strips and wonder if they would be a better replacement?
Any help appreiciated.
Were the existing connectors fixed to the oven housing?
As suggested ceramic / porcelain connectors will resist any heat more efficiently.
If in doubt then contact the oven manufacturers?
The original connectors were clipped to the housing but i have used the existing plate to securely mount the connection strip.
I think ceramic strips are the way forward, but will look to see if I can get a replacement from the manufacturer.
