Around 3.25 pence per Kwh if I remember rightlyBest thing is 2 or 5Kw heater and runs on diesel or heating oil. Face book pages for help and assistance. Generally sip fuel.
How can I have a diesel heating in a building, when I have gone to google to research, they simply talk about this being for cars etc ?
Question- assuming you have a separate fuel tank in your motorhome for the heater is it legal to run it on the cheaper kerosene or will HMRC get all excitable? V useful thread this, i had no idea night heaters had got so cheap. Need to start tracking down 24v versions for my baby lorry as well as a 12v for the garage- that running cost is v tempting
28sec heating oil(Kerosene) @ 32.5p/litre or red diesel @ 55p/litre
One thing I did not mention, I have a tall fridge/freezer in the room, is this adding to the problem ?
The construction was filled with 100mmm cavity insulation, not sure if anything else can be done ? With the loft, I can see its insulated but not sure how I can tell that is the source of heat loss.
My car has one.
Im surprised -I built a garden office which is 20 sq metres externally, I use an oil filled radiator which takes a couple of hours to warm through on 3 then I turn it down to 1.....and it stays pretty much warm enough just on low for the rest of the day
the construction is 100mm celetex in walls, 70mm floor, 120mm roof
