Hi all,
Have bought a house with a conservatory which, mounted high up on the wall, used to have some sort of heating/cooling fan contraption which I'd like to replace.
There are two pipes coming out of the wall, which I assume are coming off the central heating and these fed into an electric fan which was oblong and around a metre wide. There were various settings on the fan (so old that most of the ink had worn off of the controls) but it seems that it was a cooling and heating fan.
I'm guessing that cold water might have been used to cool air and then blow it out and hot water to blow out hot air. Unfortunately the unit has been ripped out and dumped before I had the chance to see what it was called. Any ideas as to what it might have been and if they exist anymore so I can buy a replacement? The pipes are still there and have just been capped off to prevent leaking.
A split air conditioning unit is not a possibility and although an electric panel heater mounted on the dwarf wall would be fine for heating, it won't help with cooling.
Any ideas/advice would be most welcome.
Cheers all.
Cheers all.
