At the moment, the non-combi gas boiler in my kitchen pumps hot water into my hall cupboard, from where it gets distributed to the radiators for heating and into an immersion tank for hot water, so I only get about 30 minutes of hot water out of that. There's an electric backup for the immersion tank, which I've never needed to use, and there's a cold water tank in the cupboard as well.
I'm investigating options which would allow me to remove everything from the hall cupboard so I can expand the bathroom into that space (I'd probably use it for a walk in shower). I also need to get aircon, because it reaches over 30c in my flat in the summer, so I was going to get a split aircon system, with the compressor unit on my balcony and then two wall units in the bedroom and living room. I only need cooling for a couple of months in the summer, and heating for a couple of months in the winter. I don't need any heating/cooling in the kitchen or hall, and I'm thinking of using an infrared panel on the wall or ceiling in the bathroom to provide heating in there, which I'll only need for half an hour in the mornings in the colder months (it doesn't get very cold in there anyway as it doesn't have any external walls, but it has an extractor fan/vent which lets in some cold air). I could put an aircon unit in there instead, which would have the benefit of also being able to dehumidify the room as it obviously gets damp in there, but the compressor units that support more than 2 internal units tend to be quite a bit more expensive, so it will come down to which option works out cheaper to buy and install.
I'm not sure why some places say that the difference between aircon and an ASHP is that aircon can only provide cooling whilst an ASHP can provide cooling and heating, because there's load of aircon units that also provide heating. This is just one example. Looking at the figures on p.4, it says that it uses 164kWh/a when cooling and 922kWh/a when heating. https://www.airconditioningworld.co.uk/global/media/pdf/1625133638-5855.pdf
I know aircon units can't provide hot water, although I'm not sure why when they're able to provide heating. So I'd need another option for that. I could probably fit a hot water tank somewhere in my kitchen. I know it would be more expensive to heat the water with electric rather than gas (and I'd still have the same problem that I have now, where I don't have hot water available all the time as I have to wait for the tank to fill and it runs out in about 30 minutes, which wouldn't be a problem if I removed the tank and replaced my existing boiler with a combi boiler), but maybe being able to disconnect the gas and thus avoid the standing charge would cancel that out?
Alternatively, could I get an ASHP that provides air to air heating/cooling/dehumidifying via wall units like an aircon unit, but can also do air-water for the hot water tank? Or one that does air-water for the tank and the existing radiators, but can also do air-air to provide aircon in the summer? From what I've read, it seems that there are some units called Variable Refrigerant Flow that can do this, but they can only do cooling or heating at one time (so it would be fine in the winter when I want heating and hot water, but not in the summer when I want cooling and hot water), unless you get a 3-pipe version which can do cooling and heating at the same time, but I think they're only available in big units for commercial premises (hotels, etc.) and not for residential use.
