heating element
22 Oct 2004
Cardiff
i have a suspision that the heating element is not working in my candy dishwasher i have removed it from the machine but before i buy a new one i was wondering if there are any tests i could do on it to prove it is faulty i have a multi meter but not sure what i am looking for
If you set you multimeter to the ohms setting you should get a reading between the two ends of the element.
What is the rating in watts or kW's of the element? (should be stamped somewhere on the body of the element)
From this we can give you a rough idea of the ohms reaging you should expect to get.
Also you should test between the element body and each end of the element in turn, to check for a fault to earth. You should not get any reading on your meter when doing these tests.
thanks for the advise the only markings on the element are 230v and 1950w but surely that is not the wattage also i have a meter reading of 26.3 ohms
1950W is the rating of the element in watts (Near enough 2kW which sounds normal for a dishwasher)
I work out the resistance to 27.1 ohms, so your reading sounds near enough to me.
I suspect the element is OK.
ok thanks for that, any idea`s why the water would not warm up if it`s not the element
The controller that turns the heater on and off has possibly failed.
Were the leads to the heater in good condition and not damaged ? If the cable loom has become loose it may have been rubbing on a moving part.
Could be a door switch hidden someone or even another type of switch that needs pressure or contact.I had the same trouble with a Deep fat fryer tonight it was one of those micro switches that needed to be closed before the element heated up
surely if this was the case the machine would not cycle either, which is not a problem. just got cold water constantly
