Heating/hot water problem help required..
You know, I think I've sussed the problem. I wasn't accurate enough in my first post here because I hadn't capped off the hot and cold water taps, only the hot ones and have capped the cold water supply going into the bathroom. This must be the feed into the F&E tank which explains why it isn't filling up. :?:
I thought (probably incorrectly) that the hot water was seperate from the F&E though? This is what it seemed like last night when the radiators came on but there was no water coming out of the hot water taps. Knowing this house, the F&E tank and all that stuff has probably been disconnected and I'm barking up the wrong tree altogether! :lol:
connect the cold feed back up then and you'll should get somewhere.
sounds like the hot is gravity and the cold is mains feed in the bathroom.
Well, a little knowledge is very dangerous as they say!
Everything should be running smoothly again tomorrow, but I can't leave water on at the mo because the copper push fit stop-ends I got from B&Q can't handle the water pressure from the main.
Thanks everyone, especially seco services (although technically you should thank me for giving you a good laugh!). :D
