Hi i need some advice from the experts
im having some renovation work carried out and the workers have had to take 4 radiators off. They drained the system and took them off and put stop ends on after doing so. They have now put back 2 of them, and put heating back on.
However this is where the problem has started. I have put it on timed and water priority to enable the radiators to come on and water to heat up. This is how it used to work, both would come on if set on "timed" and "water priority". I have a Danfloss Randall 3022 timer/control, and a honeywell thermostat controller in the hallway:
http://danfoss-randall.co.uk/xxTypex/305732_MNU17416279_SIT313.html
The system is gravity fed, so potterton boiler downstairs, hot water tank in bedroom and cold water in loft.
Since they put the radiators back and took air out of the radiators. The heating does not come on when on timer (it did used to). It does if i put switch to heating priority.
Any help/suggestions? im worried something has happened to the system and may be causing more serious problems.
Thanks in advance.
Thanks in advance.
