heating on all the time
15 Dec 2012
I have a combi boiler and a boilermate2 the central heating is on all the time i have changed the room stat the pump runs all the time would the fault be with the delay timer pcb or the pump pcb ?
Without seeing it or even knowing what make of boiler then I have no idea!
not sure why agile thinks the boiler model is relevant. Sounds like a board error. I forget which one controls the heating pump from memory. I think its the pump pcb, but dont hold me to that. You should be able to trace the wiring back from the heating pump
A combi boiler and a Boilermate2 is an unusual combination. Its normally a heat only boiler. :?:
it may not be a combi boiler I thought if it heated the hot water and CHS thats what defines it as combi.The Boiler is an ideal classic FF250 paired with a Boilermate 2.The problem has gone now ,the room stat is controlling the temp.No doubt the fault will return I think the pump over run PCB relay is sticking but then at the same time why would the boiler continue to fire if there is no demand.
Any ideas I have already changed the room stat ?
The Boiler will fire WHENEVER the Thermal Store (Boilermate2) needs heat and that means 24/7 the time clock and room stat only control the heating pump! :wink:
