right so the water temp can stay at 50 thats fine - what you saying correct me if I wrong is that the fault is most probably coming from the programmer thing so I need an electrician / heating engineer to do something with the wiring or replace the programmer yeah?
right ok so I'm only getting heating untill the tank temp is satisfied, when that happens and the switch moves to H does that mean that the C/H is still working or does it stop working?
ok so the H/W must be on constant, up until now I've had both the H/W and C/H off at the programmer untill I get home and need H/W and C/H I take it that is not the best thing to have been doing?!
