Hi.
I have had an extension built to the rear of my bungalow and I am ready to install the heating system.
I have carried out some of the work myself, but have got in tradesmen when I needed them.
I do not have a trade, but have done quite a few jobs with a family member (a roofer) over the years.
I have also worked with some of the other tradesmen and have picked up things from them.
I realise that it's not the perfect setup, but when you are trying to stick to a tight budget, it's difficult paying trades to do every little thing.
On the plumbing side, I will be doing all the pipe work (i've done this a few times in the past and will have it all pressure tested) and I will then get a heating engineer to connect the gas, connect all the pipes to the boiler and commission it.
A friend (who has just qualified as a plumber) was at the property last week doing a few things and he told me that I should come off the boiler (for the hot and cold) in 15mm, straight into 22mm.
Would this be of any benefit, seeing as it has to go through the 15mm pipe first.
I then gave him a brief description of the bungalow to him, so he could show the engineer that he uses.
In total there will be 2 en-suites, both with a toilet, basin and shower (run of the central heating). A bathroom with 2 basins, a toilet, a bath and another shower (run off the central heating) and a kitchen with a sink.
He has not been to the property, but have said straight away that a combi boiler will not work and I will have to have a cylinder put in somewhere.
The problem I have is that the ceilings are vaulted, so I don't have an attic space.
Could I just change the shower to electric or would this make no difference.
I am having conflicting advice from a few different people and want to get it right first time.
Thanks.
Thanks.
