Hi all
I have the above boiler which has a fault that is just dragging and dragging...getting rediculaous now.
hot water every say 20 secs on and off..(boikler cuts in n out)
so far water sensor change..secondary heater exchange, (was visualy great condition no sign in and around of build up of any type) tryed new c.h sensor no joy, checked water pump..all fine...
hot water works with c.h sensor removed but of cause at low/med temp..any higher and boiler will cut out due to heat....
Now were on to a blockage in main exchange or a pcb fault..really would love some pointers..cant keep paying for someone to try different things..heatline cost me main bulk, buy saying to swap exchange..
p.s My engineer finds it hard to beleive that theres a blockage when no signs in secondary (unless broken integral part in exchange), so he leans toward pcb.. heatline say flush ..theres a flow restriction, as boiler is doing its job and cuts out at 79c after a few mins even with c.h removed !!!!
