It is all in the instructions, Heatmeiser Slim line (12 volt 3 Amp max) has a remote air sensor, and Neostat (230 volt 3 Amp max) has a remote air and a remote floor temperature sensor. Neither suitable for electric as current too low, and which is used for water would depend on the water system, in the main there is a manifold which limits floor temperature by limiting water temperature.
To fit underfloor heating on ground floor means often lifting floor to fit insulation, and the major problem with any under floor is the heat/cooling time, there are two reasons to fit, one is to dry the floor in a wet room, the other is to use the heat from a back boiler, with solid fuel heating what you want is to delay the house cooling once fire has gone out, and for this under floor works.
As to warm floors the plinth heater works better, the fan assisted radiator blows warm air across the floor so it does warm floor, and is also fast heating the room, so geofencing works. However both fan assisted radiators and underfloor heating is expensive to install, under floor heating also expensive to run, where fan assisted cheaper to run because so easy to control.
Son has underfloor heating in bedrooms, it is solely to get rid of excess heat when solid fuel cooker is used, stops the water boiling.
