Heatslave 15 19 control / thermostat
29 Nov 2010
Cleveland
Hi all,
We have a Heatslave 15/19 floorstanding oil fired combi boiler, it's a good boiler but we do not have any thermostatic control in the house - heating is ON or OFF and only control we have is valving rads and changing the temperature knob on the boiler.
Can anyone advise what we need to add to the system to enable thermostatic control. Nothing too extravagant, just one stat will do us.
Can I get something from Worcester or do I need to go with a Siemens set-up?
Thanks in advance, any help much appreciated.
You should have at least time control and a room thermostat or a programmable room stat on a combi. To prevent firing for the HW store overnight, fit 2 channel programmer.
Worcester do their own 2 channel programmer, but I prefer to use external Honeywell stuff.
Hi Tibbot, thanks for your reply.
there is a programmable timer for the heating/hot water on the boiler it's self.
So do we just need to look at getting an external stat to link with this timer or do i need somethingto link this to the stat too?
(sorry I know these are really stupid querstions but I called into plumb centre and the guy couldn't 9or maybe just didn't want to!) andwer my questions).
It works between the timer and the boiler switch live. The boiler control thermostat s/be left alone on a high setting.
I hope no one minds me sticking my oar in here, but if the 15/19 shares the same control board as the 12/14 (and I think they do), there are terminal connections on the board to serve an external stat. Going to be one of my jobs, come the Spring.
John :)
John :)
Quite right John, The terminals are marked on the board. Take out the link and wire in the stat.
